What should i upgrade (what will be obsolete first)
ronandexsga
Commendable
Sep 28, 2016
43
Hey guys i built a rig last spring and starting to think about upgrading i currently have the following
I5-6500 skylake 3.2ghz
Z-170a asus MOBO
asus Geforce GTX 960 4 GB
rip jaws V ddr4 8GB of ram
kingston 120 GD SSD
western digital 1 TB HDD
what do you guys think will be the first to fail
should i go with more RAM 24 gb maybe or a new gygabyte 1060 gpu ?
my whole system runs pretty much everything at max under load at 30 degrees celcius
I have 4 case fans Hyper evo 212 push/pull config ?
When do you think my GPU will be obsolete
awesome thanks guys and also i Curently have 2 4gb stick in my 2 main dims slots can i take these 2 put them in my secondary dimms and add 2 stick of 8 gb for 24 gb of ram would this work ? and how can i fit a 4th stick with the eve 212 seems pretty tight fit any way to remove the plastic on top of the stick ?
Latest posts
