What should I use for a wifi card PCI or PCIE x4
Adrian77
21
hi i just built my new computer and i discovered that i need a wifi card because the Ethernet wouldst reach so after deciding USB or PCI i went with PCI. back to the question these slots are what i have available which one should i choose? BTW if there are any good wifi cards out there don't hesitate to tell me
A PCIE wifi card is better as you won't have enough space for a PCI wireless card underneath your graphic card.
Another option is to go with USB wifi adapters
thank you so much! would you recremend any
What do you plan to do with your computer?
How far away your computer will be from your wifi router?
What router are you using and do you know its range and its network performance?
You looking for at USB or PCIEx4 card?
Would you like to have 802.11ac or not?
Your budget?
its on the other side of the house so id say over 50ft and it reaches my laptop just fine (this is where my computer will be).netgear N150 WNR1000 v3 and im looking at a PCIEx4.
so it turned out its (the first one) not windows 8.1 compatible so instead im just going to go to best buy and get one of those but thanks anyways
My bad, I forgot to check if the first wifi adapter was Window 8.1 compatible. But the intel one is be compatible.
http://ark.intel.com/products/75439/Intel-Dual-Band-Wireless-AC-7260?_ga=1.146938231.1399595901.1421711781
