What should my Ghz and voltage be for my 1080 TI?
shen.matt92
Commendable
Aug 4, 2018
66
I have precision XOC by EVGA and a EVGA GTX 1080 TI FTW3. The default clock is 1569 and boost 1683 I believe.
I tested Fallout 4 and in the bunker hill level where you get in this huge fight the fps minimums at 57 if its at 1873MHz but if I OC to 2GHz (2050MHz) the fps drops to 55-56 minimum. Proving 1873 is more stable? The voltage is 1062 and memory clock is 5508.
Im kind of new to this, so I was wondering what voltage and MHz combo I should select to get best performance.
My specs are
ASRock Z370 Pro4
8700K OC using EZ OC in BIOS (I think its 4.7GHz)
16GB DDR4 @ 3000MHz XMP
Hi shen.matt92,
the minimum frame rate doesn't say anything apart that it was an intense scene.
You have to look for average FPS.
First, desactivate the EZ OC in bios. This king of auto overclock overvolt your CPU making it warmer than it should for a given frequency.
Second, how did you overclock the GPU?
Third, what is your power supply?
Rodolphe.
I OC the GPU using precision XOC by EVGA, its like MSI afterburner. I heard afterburner is the best but since I have an EVGA card I wanted to with EVGA software.
My PSU is EVGA 850 G3. Interesting about EZ OC. So should I try OC it the oldschool way? Ive never done it before and since every BIOS is different, seems like Id need someone to pay me special attention online or have an expert come over. What about Intels fine tuning utility software?
If anyone here knows how to OC, I can upload pics of all the BIOS pages and I would pay you to guide me through it!
