It seems like no one knows what size heat shrink to use. I am using Para cord to go over all my cables "SEPARATELY NOT ALL TOGETHER" and i need to know what size heat shrink to use on the cables after the paracord is non them.
BUT, how are you planning to fit the power connectors through? Re-crimp everything or do you have modular? If you have modular, it should already be sleeved with a weave of some sorts.
Just a thought.
Sweet Jesus i am not heat shrinking a bunch of Trees man! lol The cables are 2mm thik as it is but i dont know how much thicker they will be with paracord on them. And no you just use a ATX tool and it opens the fins and you pull it out than sleeve it. I may go without heatshrink but idk if it looks good with or without heatshrink. Here is what paracord im using below. Oh and to really make you cringe i am doing all this on a NON modular PSU 😉 But it can be done as i see many people doing it.
You could always get an assorted box and give each a try, personally I would think around 2mm would be sufficient...
http://www.amazon.com/Anytime-Tools-Shrink-Sleeve-Assorted/dp/B008WWC6FU/ref=sr_1_1?s=industrial&ie=UTF8&qid=1442893403&sr=1-1
Well the cables are 2mm thick already and i heard heatchrink shrinks half its size so im guessing 4-5 mm
I forgot to include paracord in that... Guess its a good think its a multi sized kit.
Given the size of the para ive used, 4-5 should be good.
Buuuut i want white heat shrink :/ Hey maybe walmart or Radioshack has some or dollar general and i can test it than order a colored one. I heard it looks better without heat shrink though so what u think?
I personally like it without, but its harder to do that way.
Well i think its easier because all you do is melt the paracord and pinch it near the end where the pin starts. I heard its harder because most people are scarred from burning themselves but where i have NO feeling in my finger tips from playing guitar so much i never feel it lol.
If you are comfortable using a lighter with your PSU cables I would just do it that way lol
Lol ok i just wanted to get some opinions on it cause i mean its the first time me doing it lol. I mean i have done years of electircal and wiring i just never sleeved anything with paracord and i think it looks soooo awesome.
