TommyFamzy :
Terrorsquad1990 :
TommyFamzy :
Should i set them up so air is blowing into the radiator or into my case? i want to be as clear as possible
You need to put them as exhaust. So basically you'll be putting them like this:
http://imgur.com/a/dMG7Q
This is my cooling and its radiators.
You want them to blow air from inside to outside
How easy is it to setup just mount it to the case, put the backplate on seat the water block and plug the fans into cpu fan slot?
1. Put backplate onto motherboard
2. Put screws onto front side through backplate
3. Attach fans to radiator
4. Attack radiator to case and attach their 3-pin connectors to CPU_FAN header on the motherboard (should be right on top, right side)
5. Attack waterblock to CPU through the screws you put on there and thumbscrews you"ll use (those thick ones) and attack
6. Extra; attack mini-USB to waterblock
7. Attach mini-USB header to motherboard USB 2.0
8.???
9. Profit and fun!
10. Oh and download Corsair Link as this will be your driver. And also the program to change the LED
It's prolly the most easiest thing asside for putting RAM in
