I've got a 931gb seagate already in there and that's all the info I can give on the hard drive.
So how many can I fit in? will there be a cable issue since I have SLI GTX 970's in there? I was hoping for x2 hard drives (total of 3) to be put in there.
How do I install it into my case, does it come with clips/screws that are universal with all pc towers? and I take it sata cables wont be a problem either?
I have a standard(non-branded) 850 Watt PSU and my MoBo is Z97X Gaming 3.
Thanks in advance.
Edit: It will be normal HDD's btw, info on SDD would be nice too if you can, no room for PCI-E SSD though, the GPU's have clustered and need Fan room.
Thanks in advance.
