[SOLVED] What sound card? What speakers?
omnilicious
55
8
18,545
I know I want a sound card. They make a difference, but I'm unable to find a good resource for what is a good one (posts from last year, not sure if they're still relevant).
I keep hearing about how much better DAC's/AMPs are, but I also kinda don't care. Most of the ones I see linked have a few problems including being external and thus another object on my desk, single output for headphones, not sure how expensive 5.1/7.1 gets with them.
Logitech Z906 5.1 Surround Sound Speaker System - THX, Dolby Digital and DTS Digital Certified
https://www.amazon.com/Logitech-Z90...g=wpcentralb-20&ascsubtag=UUwpUdUnU39790YYwYg
These are what I've seen for speakers that are a decent price and recommended everywhere - but is there better for that price range?
Currently just have a 5 year old set of audio-technica ATH-M50x. Might be in the market for a newer/better set, but I might wait until these actually quit on me.
My generally recommendation here would be the Creative Soundblaster Z; it's an all-around good soundcard that doesn't break the bank.
As for connection, I'd recommend connecting via analog (3.5mm); the soundcard is going to do a better job converting to analog then the DAC they have in the speakers, plus you avoid having to deal with realtime Dolby/DTS encoding (though I note the Soundblaster Z can do that if required).
