P PedsBeast Commendable Apr 3, 2017 8 0 1,510 Jul 10, 2017 #1 Like i need to know the type of connectors and cables that connect to the motherboard it is suppose to have and all of the functionalities. If someone was able to elaborate i would be extremly grateful
Solution Aeacus Jul 11, 2017 It completely depends on which RGB LED strip kit you're planning to get. Here are 3 main RGB LED kits explained, link: http://www.pcgamer.com/the-best-rgb-led-lighting-kit/ I have HUE+ in use in my Skylake build and i'm pleased with it.
Aeacus Titan Mar 21, 2015 14,101 2,593 84,890 Jul 11, 2017 Solution #2 It completely depends on which RGB LED strip kit you're planning to get. Here are 3 main RGB LED kits explained, link: http://www.pcgamer.com/the-best-rgb-led-lighting-kit/ I have HUE+ in use in my Skylake build and i'm pleased with it. Upvote 0 Downvote Solution
