What specs to look at while buying a Monitor.
JerrWolf
447
5
18,795
I'm looking at these two monitors. One is upward $600, the other is upward $400.
the first is a 2k monitor while the second is a 4k monitor, on sale.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236399
http://www.newegg.com/Product/Product.aspx?Item=24-236-405
What should I be looking for at which is best for me.
I have a i7 4790k and GTX 980 ti ASUS Strix for CPU/GPU.
I am currently using 1080p monitor, and I'd like to upgrade and have two monitors, older one for browsing and etc while new one for main monitor and games.
I am unsure if I will even use 4k in games often. I prefer 60fps in games.
Is it a waste to get a 4k monitor then? Is it a waste in this case being that it is cheaper than the 2k monitor?
The 4k one has a contrast ratio of 100 million:1, so it'll look good even under different lighting environments, where lower contrast ratios like 1000:1 would have a noticeable difference in display performance between natural light and artificial light... But if it's always under the same lighting, then in my opinion, anything over 750:1 is enough.
I'd go with the 1440p monitor simply because of the fact that 4k is a pretty heavy load even for a 980ti
The 1440p monitor looks rather impressive actually... And to be honest, even the higher models of the board partner variations of the 980ti will have a hard time running multiple screens smoothly if you're 4k gaming on one of them.
To answer your question about which specifications are important... I look at response time (gray to gray) as well as resolution, contrast ratio and refresh rate. A 1000:1 contrast ratio isn't the highest there is, but it'll be fine as long as you don't have multiple different color party lights in your room that cast their light on your screen. I've heard of one screen (the Acer Predator I think it's the X34) that has a 100 million:1 contrast ratio.
