Question What speed can i achieve overclocking my memory?
lofthouse1982
182
Good morning, I would like to know what is the maximum i can overclock my memory?
Corsair Vengeance LPX 16GB (2x 8GB) 2666MHz DDR4 x2
Memory
Memory Size16 GB
Memory TypeDDR4
Memory Speed2666MHz
DesignationPC4-21300
Number of Modules2 module(s)
Pin Configuration288 pins
Electrical
Voltage1.2 V
Physical
Form FactorMemory Kit
Warranty
WarrantyLifetime
Key Features
Memory PackageDIMM
Individual Module Size8192 MB
Memory Modules Kit Size2
Memory StandardPC4-21300
Memory CAS16
Memory Voltage1.2 V
Memory ECCNo
Memory BufferedNo
XMP SupportYes
Item Details
ManufacturerCorsair
Manufacturer CodeCMK16GX4M2A2666C16
UPC843591069618
ConditionNew
I run a B450 Steel Legend motherboard
Thanks Richard
Ralston18
Two parts: what the motherboard can support and what the RAM modules can run at.
The guiding document is the Motherboard's User Guide/Manual.
https://www.manualslib.com/products/Asrock-B450-Steel-Legend-10771269.html
Do verify that I found the applicable manual. Make, model, and revision matter.
Supported motherboard RAM configuration are listed starting on physically numbered Page 22.
How most manuals also refer you to the Motherboard manufacturer's website for more and updated information.
You can also find similar information via the RAM module manufacturer's website. Look for a consensus.
Details matter so read all the footnotes and fine print.
Do not exceed the specs and it is recommended that you start at the low end and test upwards in increments.
In any case ensure that the PSU is able to support the overall system power requirements.
Lutfij
If the ram kit can go farther than DDR4-2666MHz, then you should be able to go to DDR4-3200MHz with relaxed timings and a voltage of 1.35v or 1.4v. On another note, to add to what my colleague above has stated, make sure you're on the latest BIOS version as well prior to overclocking.
