What speed should my case fans go at?
nozzy7
242
So I was wondering what speed my two case fans should run at they are both currently running at 1400 rpm which keeps my case temp at 28C. My motherboard is around 28C and my CPU is at 36C on its stock cooler. Under load my case temp is 30C my CPU is around 40C I do not know my motherboard's temp under load. My question are my fans working harder than they need to?
Didn't know what category to put this in.
Those temps and fan speeds are fine. I would only adjust the speeds if there (1) too loud (2) temps are too high (3) fan speeds are well over 3000 rpm.
Thanks this is my first build so every thing is new territory for me and the fans seem to be silent enough but noise is not a big deal for me.
I was using my bios but I the setting options are limiting so i will give speedfan a try thanks.
