Hello. I was wondering what stock fan/heatsinks can i use for a i5-4570S??? I am upgrading from a G3258, both are LGA1150, can I just reuse the one that I installed with the G3258? Will any LGA1150 Intel stock Fan/Heatsink work or does it need to be the specific one that came with it? If there are only some models that are compatible, do they list them anywhere on the web?
Thanks for any and all help
PS> To be clear, I bought a CPU from a company that came out of a tray so it has no stock fan/heatsink included which is why I am wondering if I could reuse the G3258 one that is in there or should I buy another one. I like the stock ones because they are simple to install. I tried a "good one" before and never could figure out how to install it proper (probably because of my big sausage-like fingers LOL) so I wound up using the stock one and have ever since. If you know of one that is as simple to install, well then that would be a possibility. Thanks again
