What the best CPU for thats compatible with my motherboard?
@techandhelp2000
Go with DarkEngine's suggestion.
But do compare the CPU specifications.
Frame your question in terms of requirements: e.g., what cpu specs will not "let you down"?
You may need to consider a different motherboard with more CPU options.
How do you intend to use the computer? What other components will be installed?
The motherboard's manufacturer should provide a list of compatible CPUs.
You need to establish the required performance levels for your use of the computer. Plus you need to consider budget - how much can you spend?
gaming PC
i have already got a 1070 and i feel like my cpu is letting me down which is currently an i5 4670
@techandhelp2000
