What the difference with Palit GTX 1070 Dual, JetStream and SuperJetStream?
Sevando
Commendable
Aug 21, 2016
75
I was wondering what is the difference of these 3 card graphics of Palit? i think it's little cheaper Palit Dual on my country and i was thinking it's worth for buying a daul? i use it only for games if i buy the dual of the other for the new games which released
Dual --> Basic.cooler, 1.5slot Card
Jetstream --> better cooler, 2.5 slot card
Super Jetstream --> same as Jetstream
Gamerock --> same as Jetstream but the heat pipe is in direct contact with the memory and cooles the card even better therefore
Seeing your build, you won't need a sound card unless the onboard sound is defective
I'm in greece sorry for the late answer my budget is that:
if i forget something tell me i also worrying maybe have bottleneck in my pc
I can play all games suitable? Battlefield 1 I heard is a bad game at optimization and more
PC Case: Aerocool 1000
CPU: Intel Core i5 4590
Motherboard: Z97 Pro Gamer
Sound Card: Sound Blaster Audigy RX
CPU Cooler: Cryorig H7
RAM: 8GB Ram
2x WD Blue Caviar 1TB
1x OCZ Trion 150 240gb
It was a gift i didn't buy it really but anyway there is another problem which i worry my pc build is suitable for 1070 card graphic? there is any chance of bottleneck i really worry about that because some people told me about that 1070 will do a little bottleneck i don't know
So i5 4590 and GTX 1070 is a good combination?
Maybe should i buy later another cpu just in case?
i'm in haswell i really don't know if this worth for changing socket and ram and cpu together
yes i agree because i see that i don't do an overclock or something more
i also forgot i have G650M psu so why not to go later for 4790k that could be a good upgrade
Sorry for necroing but couldnt find info on those cards elsewhere
what about PCB components quality?
