I made a thread earlier and a guy was kind of helping me, He ointed me in the direction of a format and fresh windows install. However he was only an apprentice, So i will ask again.
My current system
Asrock 970 AM3+ Extreme4
Phenom II x4 Black Edition 3.4ghz
8GB Vengeance Corsair Ram
Sapphire Radeon HD 7850 2GB OC Edition.
ALL my temps are fine, My card and cpu idle at 25c and underload max at 50c
The problem i am having is frame rates. Firstly i get some split second stutter and my fps drops then goes back up to the 60fps that i usually get. I have been testing some games, Som games do it and some dont.
The other issue i seem to be getting is, I get the same FPS on ultra as i do on Medium/low.
I just played Saints row 3, I was getting 80 FPS for a while, then it went down to 55-60. After a while it dropped to 30 FPS , I turned the graphics down to high...Stayed the same, Put the graphics on medium..I gained 1 or 2 FPS.
Am i missing something here? I know i dont have the best rig around but it should handle every game out atleast on medium settings while running alot on Max settings.
Will a fresh install fix my issues?
EDIT: Could this be because im playing in full screen? My Screen rez im sure is 1600x900 and im playing in that.
My current system
