What to do with 1 more fan
Nov 26, 2018
20
Hey guys.
I have a Masterbox lite 3.1 case, which supports 3 case fans. Now I have 1 fan which came with the case, and Im planning to buy a 3 fan set with a controller. Is there any way I can make a good use of the plus fan? Theres no dedicated mounting place in the case, but you might know a good solution how to make it useful
If you feel particularly industrious, and if there is enough clearance between your motherboard and cpu cooler and where a fan might interfere inside the top of the case if it were mounted there, this is the only actual option I see for another fan unless you have a tower CPU cooler that uses the same size fan, and then you could possibly add it to the backside for a push pull configuration.
https://www.youtube.com/watch?v=2ZOZujVvMr4
I have a ryzen 5 2600, asrock b450m pro4 mb, asus gtx 1060 gpu. The case is an mATX case
Im not cutting my case, Im not barbaric, thx for the tip tho. The other idea gonna work for me. Im planning on buying a be quiet tower cooler which comes with 1 fan only. Never thought of what you said, so thanks now I have my answer!
