[SOLVED] What to Do With Extra 4 Pin RGB Cable on Splitter
ysDlexia
5
Hi all,
So I’m in the home stretch of my new PC build, and I’m trying to set up the two RGB fans on the front of my case (CoolerMaster MasterBox H500). The case came with a 3-to-1 RGB splitter, but only has 2 RGB fans, so I’m stuck with an extra 4 pin connector sitting exposed.
Am I correct in assuming that this exposed connector would short my motherboard if it comes in contact with the back panel? If so, any advice on what to do about this?
