J jeraldtapz Honorable Sep 19, 2013 66 0 10,640 Feb 26, 2014 #1 What if my motherboard doesn't have a usb 3.0 header and my case does. Is it okay to just tuck the usb 3,0 connector with the other wires and not use the usb 3.0 port until i get a usb 3.0 to usb 2.0 adapter?
Solution EasyLover Feb 26, 2014 Yes, you can safely tuck that USB 3.0 connector inside the case till such time you get USB 3.0 adapter or change the mobo. No Issue.
ldewitt Distinguished Sep 27, 2013 1,034 0 19,660 Feb 26, 2014 #2 Yeah that's It only means you will not have functionality out of those USB ports. Until of course you get that adapter. Upvote 0 Downvote
EasyLover Splendid Dec 30, 2013 6,551 0 24,960 Feb 26, 2014 Solution #3 Yes, you can safely tuck that USB 3.0 connector inside the case till such time you get USB 3.0 adapter or change the mobo. No Issue. Upvote 0 Downvote Solution
