PCI adapters run faster as there is no USB data flow restriction, It is internal no chance of losing the little adapter when going to and from lan party's, able to use different antenna's to maximize signal strength, adjustable antenna's to receive the best signal possible.
you say a lot of people have problems with a 4 egg rating? you don't get a 4 egg rating if the product was bad. many people don't realize that router settings can cause connection issues as much as the adapter setting.
