I have noticed that I will have 12 fans(!) in the case for my new build (1 in PSU, 2x120mm on CPU-cooler, 2x120 for Chipset Cooling, 1x120 Kama Bay, 1x120mm,2x200mm exhaust and 1x200mm intake in case plus 3x120mm optional fans for better airflow). The 200mm fans are rated at 12V and consume 3.4W. The 120mm ones, no idea. Will be a mix of scythe, noctua and cooler-master fans until I unify them later.
Overkill, probably. Still I am looking into controlling the majority of the fans (4+6 for 10 out of 12 fans) through a Kaze server and Kama Panel 2.
Micromanaging? Unecessary? Gonna do it anyway? Yes, Yes and Yes. 😀
Here is the question though:
Is it possible to destroy a fan OR a controller using a combination of the above-mentioned fans/controllers?
If so, when?
Is it possible I will not be able to effectively reduce the fan speed on some fans enough for there to be any difference in sound-level?
What should I check to make sure the fans are compatible and my new build doesnt burn down my new house? 😀
Sorry for the Noobish questions but this will be the first time I am using fan controllers since I am going for a silent (when idle) build.
Thanks in advance,
-Inq
If so, when?
Thanks in advance,
-Inq
