P Packard93 Commendable Jul 20, 2016 123 0 1,710 Sep 24, 2016 #1 I need a tool that can measure the pci express slot power draw > Is there a section in gpuz that does this?
Solution Rogue Leader Sep 24, 2016 No. The review sites use external equipment to do these measurements, there is no program that can do this.
Ethanh100 Honorable Jun 10, 2014 1,208 1 11,965 Sep 24, 2016 #2 No, it would require an instrument that was hooked up to the pci slot itself, so nothing you can really do as a regular user. Upvote 0 Downvote
Rogue Leader It's a trap! Moderator Dec 22, 2014 33,376 3,239 116,640 Sep 24, 2016 Solution #3 No. The review sites use external equipment to do these measurements, there is no program that can do this. Upvote 0 Downvote Solution
k1114 Titan May 2, 2010 14,236 93 75,540 Sep 24, 2016 #4 There is nothing that can measure it without external equipment. Upvote 0 Downvote
