What type of Ethernet cable should I use?
sparda1
142
Hi all. I've been having a lot of Wi-Fi connection issues on my Blu-ray player, while streaming netflix, which is upstairs from where the router is located (I have no issues at all streaming wirelessly to my PS3, which is on the same level as the router), so I thought I would try a wired connection and see if that will help. It's been many years since I last bought an Ethernet cable and was unsure of what type I should I get.
I need approx. 50 feet and I see several different types available online for roughly the same $10-20 price range: Cat5e, Cat6, Cat6a, Cat6e and Cat7. So my question is, what type of cable should I buy? Does it really matter? I read that Cat6 is better for longer distances, but I doubt that matters much in home networking.
My router is a Linksys WRT54GS. Thanks =)
The wired ports are 10/100, not gigabit. So category 5 on up will be fine. Cat 6 is pretty good all around for everything up to and including 10Gbase (10 gigabit), however it can be troublesome at those speeds over long distance...
Not a problem you are likely to encounter in home networking.
hey man mmm ive brought a ethernet cat 6 cable and wondering if ill still get the same internet speed im im right next to it with the cable and if im 8 meters away. my computer is 8m away from my router and im asking if im going to experience internet problems.my internet speed is 76 mb. thx man
hey man ive got a 5e what exactly is the difference because ive just ordered a 8m cat6 enthernet cable and wondering if its good and will it give me the same internet speeds when im close to my router with the cable connected and 8m meters away and still get the same speeds or what? thx man
