Question What type of GPU cooler will work with a Geforce RTX 2070 (not super)
Sep 18, 2019
I'm searching for a GPU cooler that will work with my 2070 but I can't find any on amazon that specifically work for the original. Every time I put a game on with Ray Tracing the computer starts to overheat and also rattles. I don't know if this could also be an issue with the power supply as I got it pre-built. Anyone have any recommendations.
Phaaze88
Herald
Rattles? Sounds like the case doesn't like when the gpu's fans ramp up.
Most likely poor airflow through the case.
Can you post the specs of the PC?
-cpu
-motherboard
-exact model of the 2070
-power supply - the make and model can be found by opening the case up and finding the label on the unit. Ex: Corsair RM650X.
-make and model of the case
rubix_1011
Contributing Writer
"the computer"
Which part of the computer? CPU? GPU? Hard drive SMART thermal sensors?
How do you know the GPU is causing the rattle? This seems like you are attempting to solve for a problem that you aren't even certain what is causing it.
