What type of pin do the Deepcool Tesseract SW Case fans use?
bibknob
6
Hello
So I've been searching for a while now and i just cant find a definitive answer.
So I'm buying a Deepcool Tesseract SW Mid Tower case which has 2 already installed fans and I'm using the MSI A320M BAZOOKA Motherboard. (Budget build btw) Will they work together?
Thank you
Case fans generally use 3 Pin connectors and/or molex.
That motherboard has two 4 Pin connectors for case fans. You can also plug 3 Pin fans into those connectors.
So yes, they are compatible. But if you want more fans, you will need some sort of splitter or molex adapter.
We could confirm if you could shoot us a picture of the wires leading out of the fan and terminating on the connector. Often they should be 3 pin fan connectors but it's also possible that they are molex powered and will not plug to your motherboard.
i have a deepcool case, kendomen (come with 5 fans) not tesseract, front fans and rear fans are 3pin, top fan are 3pin with a 3pin to molex extension. i think all their low/mid tier case fan provides the option using 3 pins, if you want to, but they don't assume that you have 4+ fan header on the mobo,
your msi board has 1x cpu fan header + 2x fan header,
you are good to go.
Awesome guys! I was gonna get the ASRock AB350 Pro4, but after seeing the 50%-50% reviews of it either working like a dream or being a nightmare, i just didn't want to risk it ha ha.
Its nice that i can get the bazooka for a bit less but with virtually the same components.
Thanks everyone
