My PC is a Dell Optiplex 7010 MT dual-booting Win 7 Pro 64-bit and Win 10 Pro 64-bit. Has 16GB RAM. Use it for SOHO work with Excel and Word (and connecting to a bigger office using GoToMyPC), not gaming. No separate card yet.
Want to hook up TWO older 17" monitors, both with VGA plugs - both 1280 x 1024 max. (One is probably analog only; the other seems to be both.)
I could use my current VGA splitter cord to hook them both up into the existing Intel HD Graphics, but should I buy a decent basic card with two sockets?
WHAT DO YOU RECOMMEND?
By the way, somewhere I have a VGA-to-digital converter plug, but I forget which way it runs. So I suppose if the card has one VGA socket and one digital socket, it might work, but please warn me - would need to check.
Thanks.
Thanks.
