what usb wire do i need for this hard disk? help
If you open up the external case ( may take a bit of effort as sometimes they glue the two halves together) you can check on the connector type of the HDD ( may be sata or mini sata or mini ide) you can then buy a new external HDD enclosure to fit your drive. They aren't expensive and are easy to fit.
what do i do then? is their any way I will be able to use my hard-disk again
THank you so much, it didn't come in my mind to get new case... Thank you for saving my data..! LIVE LONG <3
