What water cooler to fit into a Cooler Master HAF 932 Blue Edition
Kryne
20
I have a Cooler Master HAF 932 Blue Edition and I'm trying to decide on which liquid cooler to get for it. I would like to get the NZXT Kraken x61 but from what I've read it will not work with my case. Same issue for the Corsair h110, so I think I can rule that out.
Will the Corsair h105 fit into my case, if it will I'm thinking I'll go with that one. If it doesn't does anyone have any recommendations?
Based on what I can see, you need one that uses 120mm fans. The Kraken x61 uses 140mm fans, which are too big. I'd look at a Corsair H100i GTX, the H105 will fit too, but I like the H100i GTX more, it's a newer design.
