What watercooler will fit within my Tesseract SW
Keyan Mohebbati
6
Hi, just want to ask what watercooler will fit in my Tesseract, price isnt really an issue although ~150 aud is max.. I'm not going to overclock and i just want a nice cool i5 4690k. Do not suggest any air coolers as i have made up my mind that water coolers are 100% cooler... Preferably a dual 120mm one.. thanks :)
Hi man, looked at the Pcpartpicker link, and this is an extract,
"Only downside it size... I had to do the ultimate sin and top mount the fans because the case was just way too small."
Could you explain to me what the ultimate sin means, and I literally don't understand the concept of mounting fans on top of the case. Thanks
A radiator works best when cool air is drawn through it. This means that is works best when mounted in the front as an intake. Here is was mounted at the top as an exhaust. It will be less efficient because the warmer air from the case is being used to 'cool' the radiator.
The same situation will exist with ANY 240mm radiator in the case.
Unless you are just 'playing' with cooling, I would want a 240mm radiator.
Yes, sort of. Mount the fans on the radiator first and then mount the whole assembly on the roof of the case. You should have long mounting screws for that. If not, look at the instructions to see how it is supposed to work. There may be rubber anti-vibration washers that need to be installed.
Latest posts
