[SOLVED] What wattage and brand power supply for this build?
Furzumz
Hello, I'm looking to replace the power supply for my current build. The original one I bought turned out to not be the that great for this setup (oops)
What are some reputable brands I could go with and what wattage would I need?
My setup is:
2070 super
Ryzen 9 3900x
2x8 RAM
1 SSD
1 Hard Drive (will probably add a second later)
If fans pull enough power to be considered worth mentioning I got 5 case fans and 2 CPU tower cooler fans
Not doing any manual overclocking nor do I intend to, I'd probably ruin my computer
Don't go 600 though, those will generally be older platforms. Go with 650W. The Corsair CX650 series are fine. The Corsair TXM series are better. The Corsair RX series are better still. All depends on what your budget is.
PSUs are crazy expensive right now. Before the COVID issue, that CX550 you linked could be purchased for $50 or less.
