what wattage power supply do i need?
Gabe Moon
5
I don't know if the psu I'm getting will run the system I'm building.
Im using,
AMD 8350FX 4 Ghz cpu
Gigibyte GV-R290x 4gb graphics card
Gigibyte GA-990FXA-UD5 Motherboard
Thermaltake water 3.0 extreme cpu cooler
LG internal super multi drive
Samsung 840 EVO 500Gb ssd
Corsair vengeance 16 Gb 1600 2 stick ddr3 memory
Right now I'll be using a 750 watt corsair rm 80+ gold psu
D
like the previous reply, I would also say a 750W or higher would be ok. if you want to be future proof choose maybe 1000W
If you already bought the RM 750 PSU, you will be fine. Don't worry about it.
If you haven't yet, there are better options. For single gpu setups, a 650w power supply is plenty. Get power supplies from well-known brands (Antec, Corsair HX, AX series, Seasonic or XFX)
