What Wifi Card Will Work With My MoBo?
MrSalty
24
Hi all!
I'm just about finished with my budget mini PC build and I'm just trying to figure out the wifi.
My motherboard is a GA-H110N (link) and it looks as though it supports an m.2 wifi card.
I was considering this card (link)
Before purchasing one I thought I would ask the community which is a good card and which is compatible as there doesn't appear to be much info about this specific MoBo
Thanks all!!
That Wifi card will work just fine. And stick with Intel's options. The only catch is that you may need to download driver's for the card which means you'll need to have the system hard-wired in or use another computer to download the drivers to a USB stick and transfer it over
Thanks for the reply!
The only thing that's throwing me off is that it looks like the m.2 wifi card has more contacts than the m.2 slot in my motherboard. Am I just seeing things or is everything fine?
No, you're not seeing things. Those connectors on the card make contact with certain leads within the M.2 port. You can see this on NVMe SSD's and regular M.2 SATA SSD's. The connectors are different but work in the M.2 port. In short, the connector will work.
:cheese:
Thanks for the help Jwpanz! +1
Now if only you could help with my surround sound problem lol
