What will be better, 1 4k +1 G-sync monitor or 1 QHD?
XMorsX
411
108
First of all, forget Asus rog, it is overpriced and overrated. If you are to buy an expensive gaming monitor, buy the Acer XB270HU bprz. It is the only one that combines IPS panel, 144Hz refresh rate and G-Sync.
https://pcpartpicker.com/part/acer-monitor-xb270hubprz
The cheaper alternative to the Acer above is the AOC below. It is only 1080p and TN, but it has G-Sync and its color presets and contrast are much better than the ROG.
https://pcmonitors.info/reviews/aoc-g2460pg/
On the 4K I would suggest to buy a true 4K one (4096x2160) and not the pseudo 4K that are being promoted right now (3840x2160). The only true 4K you can find is this LG: http://www.newegg.com/Product/Product.aspx?Item=N82E16824025007&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
If you need to go cheaper, I would suggest an IPS pseudo4K: http://www.digitalversus.com/lcd-monitor/benq-bl3201pt-p22555/test.html
For an even cheaper alternative, consider a TN pseudo 4K, the only one with G-Sync support too.
http://www.digitalversus.com/lcd-monitor/acer-xb280hk-p21767/test.html
Monoprice is a fine monitor as far as color presets, input lag and stand quality are concerned, but it uses edge-to-edge glass which is extremely reflective and ruins the perceived black depth.
Similar threads
