Y yashimera Honorable Jun 9, 2012 1 0 10,510 Jun 10, 2012 #1 Hello, what will happen if i replace the 220 watts power supply to 700 watts?
DJDeCiBeL Splendid Dec 3, 2010 6,060 1 27,965 Jun 10, 2012 #2 Nothing really, it just gives you more wattage for a GPU, etc. Upvote 0 Downvote
rolli59 Titan Oct 27, 2007 47,791 283 130,890 Jun 10, 2012 #3 The components still pull the same amount of power and the power draw from the wall is the same presuming that both PSU's have the same efficiency. The positive as above is that you now can start upgrading. Upvote 0 Downvote
mildgamer001 Distinguished Jul 5, 2011 600 0 19,010 Jun 10, 2012 #4 it really only makes it so you can add better parts to you rcomputer later on. Upvote 0 Downvote
