What will happen if you will going to exchange the hard drive of intel and amd?
I'm not sure what you mean AMD and Intel drives they don't have specific hard drives models. If you're talking about a boot drive with windows most likely is won't boot properly and you'll need to do a fresh install of Windows right away to use it which may require formatting it so back up important data 1st. If you are talking about a data drive there should be no problem or issue just be sure you go into Bios and detect it there then save and exit the Bios and continue normally.
