What wire will I need for my PC
ANDREW3019
23
I'm ordering custom color cables from a company, and I want to know what cables I will need to order for my PC.
PC Parts that probably need cables:
    - 3.5 Drive (I know thats a sata cable)
    - ROG Strix GTX 1080 (I know theres a 4-pin for fan connectivity)
    - ASUS Maximus X Code (That hasnt come out yet, but I know theres a ATX cable)
    - Corsair H100i v2 radiator
    - Case is a Corsair 460x RGB with 3 SP120 Fans
PSU is a Rm 750i from Corsair, comes with:
    -ATX Cable
    -EPS/ATX12V Cable (which seems to be for the CPU)
    -Couple of PCI-E Cables (8-pin)
    -SATA (4 SATA is what it says)
    -Bunch of Peripheral Cables(i have no clue what that is)
    -And a useless floppy disk cable
What cables will I have to order?
simple,
motherboards use 1x24pin + 2x4pin or 1x8pin (ATX12v)
Drives use power from Sata cable (usually 2-4 sata power on a single cable)
H100i pump and radiator, use 3/4 pin header on motherboard this includes the fans associated with it. (no PSu connection)
1080 uses a 6 or 8Pin I forget to power it but any 6+2 pcie cable will do the trick
simple,
