Dr Pepper :
06yfz450ridr :
if you dont want to go wireless you c an always go powerline adapter, not always the best but they generally work well especially if your wireless is far away
I was going to go powerline adapter, until I realised I did not have an ethernet plug in my room
powerline does not use Ethernet to connect it uses your power plug, you hook one end to power then the Ethernet to your router then the other end the same way into your pc.
