Question What would you recommend for cooling and case as per my current build?
F1REF1GHTER
9
PCPartPicker Part List
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor ($158.88 @ Amazon)
Motherboard: MSI PRO B660M-E DDR4 Micro ATX LGA1700 Motherboard ($118.13 @ MemoryC)
Memory: Corsair Vengeance LPX 16 GB (1 x 16 GB) DDR4-3200 CL16 Memory
Storage: Crucial P5 Plus 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($69.98 @ Amazon)
Video Card: MSI GeForce RTX 3060 Ventus 2X 12G GeForce RTX 3060 12GB 12 GB Video Card ($354.99 @ Newegg)
Power Supply: Corsair CV650 650 W 80+ Bronze Certified ATX Power Supply
Operating System: Microsoft Windows 11 Pro OEM - DVD 64-bit ($139.98 @ Newegg)
Monitor: MSI Optix G241 23.8" 1920 x 1080 144 Hz Monitor
Hey, building my first PC. I have done some research and landed on the below build. I would like to know what kind of cooling and case will it require. Also any suggestions ragarding my current build would also be appreciated!
I'd avoid the CV units. CX, is good but a tier above that would leave you set for a long while. As for the rams, why are you picking two individual sticks of ram,? Go for a dual channel ram kit(that come matched from the factory). The stock cooler that the processor comes with will be fine. For your chassis, how much have you allocated towards it's purchase?
You could look at this cooler;
if you really wanted to get something beefy.
IMHO, I'd opt to get an i5 processor that wasn't a K or F suffix, so you have an iGPU in the event you need to troubleshoot display issues when on the discrete GPU. As of now, if your discrete GPU is faulty/failing, you will need to source another discrete GPU.
