Wade99 :
I'm looking to spend £250 on the motherboard and Xeon processor, this is just one idea for a build and I'm looking for suggestions
thanks in advance
Wade99,
The principal, desirable characteristic of a processor for gaming is the single-thread performance. That factor is dependent on the clock speed, which is why there are certain processors- Intel marks them with a "K" that can be overclocked to higher rates. Xeons, however, are locked for reasons of stability /reliability in content creation applications and will be more expensive for a lower clock speed that can't be altered. For example, the consumer CPU with the highest average Passmark
Single
Thread
Mark is the Intel i7-7700K 4-core @ 4.2/4.5GHz with a score of 2586 and cost of
£328.99 while the highest STM for a Xeon is
2440 using a E3-1275 v6 4-core @ 3.8/4.2GHz at
£327.49.
Best Cost Performance Xeon: Intel Xeon E3-1270 V2 Ivy Bridge 3.5GHz 3.9GHz Turbo 4 x 256KB Processor CPU > £140.00 + the LGA1150 Xeon E3 motherboard having the highest rated chipset according to the list above, foro example:
ASRock Z77 Extreme4, LGA 1155/Sockel H2, Intel (90-MXGKX0-A0UAYZ) Motherboard > EUR 98.00 Approximately £85.27
The Xeon E3-1270 v2 has a Passmark CPU rating of
9469 and STM of
2071
To find a list of Xeon E3 v2 compatible motherboards, go to
Partpicker UK > Start a system build > Choose CPU "Xeon E3-1270 v2" > Select Motherboard > Search motherboards by chipset designation. The performance of LGA1150 motherboards in descending order is :
Z97 chipset
Z87 chipset
H97 chipset
H87 chipset
H81 chipset
Q87 chipset
B85 chipset
Best Cost /Performance: Unless there is compelling reason to use a Xeon and new components, consider buying a used i7-4790 or i7-4790K 4-core @ 4.0/4.4GHz in the £150 range and a new or used LGA1150 motherboard at £100.
Best Cost /Performance New: Within the budget of £250, the highest performing new CPU /motherboard combination might be the
i3 7320 2-core/4 thread @ 4.1GHz for £150 plus:
Gigabyte Intel Z170 Gaming K3 DDR4 ATX Motherboard £98.48
My choice for the best gaming performance within the budget is by far the i7-4790K option.
Cheers,
BambiBoom
HP z620_2 (2017) > Xeon E5-1680 v2 (8-core@ 4.1GHz) / 64GB DDR3-1866 ECC Reg / Quadro P2000 5GB / HP Z Turbo Drive M.2 256GB + Intel 730 480GB + Seagate Constellation ES.3 1TB / ASUS Essence STX PCIe sound card / 825W PSU / Windows 7 Prof.’l 64-bit > 2X Dell Ultrasharp U2715H (2560 X 1440) / Logitech z2300 2.1 Sound
[Passmark Rating = 6166 / CPU rating = 16934 / 2D = 820 / 3D= 8849 / Mem = 2991 / Disk = 13794] 4.24.17 Single Thread Mark = 2252
