Ropuchy :
Hardware Brad :
Coolermaster Hyper T4
https://www.newegg.com/Product/Product.aspx?Item=N82E16835103182&cm_re=hyper_t4-_-35-103-182-_-Product
It looks like it has issues mounting onto AM4, based on some of the reviews.
Makes sense since this model did exist well before AM4 came out. I have personally never installed one on an AM4 socket, but this was the first one that came to mind that I knew fit both of the criteria that you were looking for. After reading the reviews, it sounds like it is mostly RAM clearance issues, possibly resolved by going with low profile RAM and not getting crazy heat spreaders?
