Espoir_1 :
When I play game the heat up to 60 or 65 in cpu and in tha motherboard up to 66 or 67 Is that Normal Temperature and I use Corsair Hydro Series High Performance Liquid CPU Cooler H60 for CPU
Your motherboard will not be that high, a motherboard will usually only be in the 20-30C range.
You may want to turn the overclock off and test your temps to see if it is getting the correct temps. An i5 with a stock cooler get about 30C idle and 60-70C at high load but this depends on your ambient room temp really and if you have much airflow in your case. Also it may be your CPU is at a fault.
I have two front intake fans powered by one molex cable each which comes from the PSU and then the standard back fan.
