Whats Difference between Mini gtx 1060 and normal?
magicbuilder
Commendable
Feb 26, 2018
41
hey everyone
So my concern is the Fps difference between the normal and the mini
The temperature difference, will it overheat and slowdown?
How low does the fps go if its under full load?
DOes it make alot of noise?
Does the 1 fan affect it in anyway?
Anyways thanks to all those who answered the question It means alot 😀
the reason why im asking this is because its 220£ on amazon for a 6gb version, since i dont trust neweggs cards even though they are alot cheaper than amazon, to me 220£ is super good price
It typically won't overheat but there are some models where they didn't design the cooler properly and the vrm would overheat. So research the one you are getting. They don't take enough power that a larger cooler is required. Of course there are some single fan models that are worse than other single fan models so how much they are different depends just as much as anything else about different model 1060s.
It is model specific as explained but I could answer for a typical model. It won't overheat and slowdown. So the fps won't go low under load. It doesn't make a lot of noise. 1 fan is just all it needs. It's the same reason lower end gpus have always had smaller coolers than higher end ones.
FPS is around the same range, maybe a few up/down here or there, but nothing significant. Definitely more noisy and hotter than the the bigger cards, but nothing that it cannot handle, unless you stay on the equator.
I have one and it does fine, no complaints.
Ty 😀 i decided now
Latest posts
