H HeavyLink Honorable Dec 1, 2015 18 0 10,510 Dec 1, 2015 #1 hi guys i have a copy of 8.1 enterprise on disk, but no activation key with it. what keys will work to activate it pro, stranded etc?? thanks
Solution USAFRet Dec 1, 2015 HeavyLink : hi guys i have a copy of 8.1 enterprise on disk, but no activation key with it. what keys will work to activate it pro, stranded etc?? thanks Only license keys from a Volume Licensing Agreement (VLA) with MS. Which you as a personal user, cannot buy. Pro or Standard will not work. Ever.
PizzaTheHutt Honorable Jan 2, 2015 1,809 0 12,460 Dec 1, 2015 #2 We don't help with Piracy but if you are installing Windows Enterprise in a corporate environment you can use a set of keys that let you get past the install, to activate windows using a different way (that is limited to corporate customers) Upvote 0 Downvote
J joex444 Distinguished Feb 16, 2006 1,279 1 19,960 Dec 1, 2015 #3 Enterprise is usually deployed in a corporate setting. Your IT department should handle this for you... Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,619 22,145 184,590 Dec 1, 2015 Solution #4 HeavyLink : hi guys i have a copy of 8.1 enterprise on disk, but no activation key with it. what keys will work to activate it pro, stranded etc?? thanks Only license keys from a Volume Licensing Agreement (VLA) with MS. Which you as a personal user, cannot buy. Pro or Standard will not work. Ever. Upvote 0 Downvote Solution
