Whats the best case for these parts and is there anything i could change about this build?
To be honest there is no difference when it comes to cooling its more "hey this one has a window" or "woah this one has RGB leds" you can buy any case you want as long the form factor is ATX so your motherboard will fit all...
Some game could be played in 4K and other would be unplayable due to low fps,it pretty much depends on the engine of the game.
And as for the case it depends,how much money can you spent? do you need a case for aesthetics? cooling? sound dampening ? what are you looking for here
Thanks for replying really appreciate it :)
i care the most about cooling. And yes i am aware about low frame rate with the 4k monitor but i can turn down resolution through the graphics options and it runs a lot faster.
To be honest there is no difference when it comes to cooling its more "hey this one has a window" or "woah this one has RGB leds" you can buy any case you want as long the form factor is ATX so your motherboard will fit all cases have an average for 4-5 extra slots that dont come with the case choose which one looks "cool" to you try to buy something that has the same color palette
