[SOLVED] What's the best ethernet cable for 1GBPS?
May 31, 2019
Hello, so my internet speed is 1GBPS, but I need an ethernet cable for this and I don't know what category I need. Thinking about CAT6. Will this work perfectly? Thank you.
Solid copper 22 to 24 gauge cat5e is all you need. Do not get flat or thin cable and do not get copper coated aluminum (CCA) cable.
