G
Guest
Guest
My system is just cooking along couldnt be more happy with it, and is fairly quiet as well. but i am thinking of adding about 2 more fans, on top mounted on the case, and a lart 120mm fan blowing in from the side pannel. I know adding these two fans will add a tiny bit of noise to the system, so i thought while i am at it i will put some oil on each of the fans just to make them run that much smoother, can anyone tell me what the best type of oil to use on case fans.?
If you overclock an Intel Processor enough, it will turn into an AMD. True Story.
