[SOLVED] whats the best graphics card I can purchase and stick right into the system without upgrading or changing any other parts?
8190andrew
16
Pc specs:
Case iBUYPOWER Revolt 2 Gaming Case - with Revolt 2 RGB Case Lighting
Processor Intel® Core™ i5-6600K Processor (4x 3.50GHz/6MB L3 Cache) - Intel® Core™ i5-6600K
Motherboard MSI H110I Pro Wifi -- Wireless AC + Bluetooth, 2x USB 3.0, 4x USB 2.0
Memory 16 GB [8 GB x2] DDR4-2133 Memory Module - G.SKILL Ripjaws V
Video Card NVIDIA GeForce GTX 1050 Ti - 4GB GDDR5
Power Supply 600 Watt - Corsair CX600 V2 - 80 PLUS Bronze
Processor Cooling Asetek 550LC 120mm Liquid Cooling System - ARC Dual Silent High Performance Fan Upgrade (Push-Pull Airflow)
Primary Hard Drive 240 GB Kingston UV400 SATA-3 SSD -- Read: 550MB/s; Write: 490MB/s - Single Drive
Data Hard Drive 1 TB Hard Drive -- 32MB Cache, 7200RPM, 6.0Gb/s - Single Drive
With that CPU I wouldn't advise putting in anything more powerful than a 2060 or RX 5700 CPU is about 100W so both of the cards should be fine with the PSu
Pc specs:
i would say anything. i mean yes you will bottle neck the cpu but if you intend on doing a upgrade in that later then no need to worry. as for power wise that corsair psu is plenty.
