What's the best Single fan Water Cooling solution for a 5820K?
0nard00
386
I'm returning my NH-D15 and will be going for an AIO cooling solution. I need some thoughts on which one would be best for this build that I'm currently completing. I'm looking at a H80i GT or a H90 atm, but would like to look around more.
I'll be using a 450D case, and the system will be used for some high-end gaming, but mostly for 3D rendering.
Thanks.
Because the fan was becoming too tall when I use heat spreaders. But I've seen my temps drop to below 10C with a FX-8350 with this NH-D15. But, now that I'm moving to a different set of RAM modules, I just remembered that these ones don't really have Heat Spreaders.
So, I'm strongly considering the options. Plus, this cooler is very quiet, compared to my 212.
Another thing is, I might go after a FuryX, which would be hard to route alongside an NH-D15.
It's actually in the process of return. So, I'll compare before I rebuild my PC, and switch to the 5820K.
Hmm.. Doesn't look like a big difference. If I wanted to, I could just re-use the other fan when needed. It's simply a single fan NH-D15. lol
I'll think about it hard, I'm not sure how much the shipping will be for this guy, if I return it.
Hmm, Yeah, two fan thing really limits you. But that clearance under it helps. Just not with really high heat spreaders.
Here's the system it's running on right now, the photo's aren't updated but, whatever error you see there... Has been fixed.
https://pcpartpicker.com/user/0nard00/builds/#view=T4WXsY
With the RAM that I got for the 5820K build, it doesn't look like it has high head spreaders. So, I don't think I'll run into fitting issues. I just wish I could exchange my 450D for a 750D instead. An Enthoo Pro would nice, I'm just not a fan of buying big stuff online, too much risk involve.
The Kraken X41 is a really nice choice. X61 is a bit big, but I might consider it.
I'll be returning this NH-D15, probably sometime this week, then, I'll order whichever of the two feels the best--- probably today.
