What's the Difference Between 150Mbps and 300Mbps Wireless Network Adapters?
First you get nowhere near those magic numbers in real world. Most times to get over 100mbps you need 802.11ac devices.
The main difference between those 2 is the 300mbps one attempts to transmit 2 different overlapping signals on the same radio channels. They do surprising good job of extracting the data when you consider they are intentionally sending singals that interfere with each other. As you move up to say 450 or 600 going to 3 and then 4 signals they are less successful so the amounted added each jump is much less.
The main difference is the speed it caps off. 150mbps will not receive/transmit data any faster than 150mbps and likewise for 300mbps. Of course your internet would have to be able supply that sort of data bandwidth or whatever device you connect to wirelessly.
As for daily tasks and gaming you won’t see any difference as long as your internet is below that threshold of 150/300.
