I've recently bought a GTX 1060 6GB MSI mini(single fan) and I would like to know how inferior it is compared to a regular sized one(3 fans) with the same specs.
Thx in advance for any input!
How do I pick this reply as the solution?AFAIK the only difference is the single fan model gets a bit noisier than the dual fan ones at full throttle. They are intended for SFF builds. Otherwise the clocks are the same as the reference models. Triple fan 1060s are more likely ‘OC’ models with a factory overclock applied.
