What's the difference between CPU temp and CPU Package Temp?
d_A_e
Commendable
Jun 24, 2016
95
So basically I see two "CPU" temps and one package CPU temp; what do they all mean, moreover, are they good temps?
For what it's worth, temperature readings from anything other than AMD Overdrive are usually nonsense for FM2+ chips. A core temp of ~54 fahrenheit, even at idle, seems pretty unlikely to me unless you keep your computer in a freezer.
